![]() | Home > Technical (L322) > 2010 4.4TDV8 canbus / electrical problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
first check would be the battery and then the alternator.. ... - .- -.
Alan_B Member Since: 04 Jul 2016 Location: Lisburn / Northern Ireland Posts: 11 ![]() ![]() ![]() |
The recovery guy tried a jump pack onto battery, no joy, did not register the key etc. Have also tried the spare key and exact same problem. |
Sounds like a dead battery to me as well which could also be caused by a failed alternator. A replacement battery is not that expensive (cheaper than a trip back to the dealer) and even if the battery was 'OK' it would have been wise to replace it as a new owner. Also replace the batteries in the keys. Replacing the alternator is a bit more involved but not beyond a competent mechanic/ garage. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Just don't fit a new battery before checking out the alternator as the main rectifier diodes often go short circuit draining the battery very quickly. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Really common on the 4.4 TDV8 for the alternator to fail and drain the battery.
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 20 ![]() ![]() ![]() |
This happened to me lots of things lighting up on the dash & within a few minutes the was dead, dead short in the alternator. |
