Home > Range Rover Classic > Footwells wet
Bluestu33
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
Footwells wet
Morning all!
I’m starting work in my classic and have noticed that the front footwells are wet.
I have removed the carpet and soundproofing and they are soaked.
The two grommets were not in their holes, so I have put them back in.
Just checked the car this morning and the footwells are wet again.
Any ideas on what I need to check please?
It’s a 93 with air con, but no sunroof. The drivers window seems to have some condensation, but the passenger window doesn’t. The car is stored under cover so not out in the rain.
Thanks in advance!
Post #660744 31st Mar 2023 9:01am
Merchy
As you said that you are starting work on your classic, I assume that you have not started the engine. If the car is under cover then the water could be a leak from the air heater, then the water will run down under the carpets, never worked on a 'classic' but I would check the coolant level, this could well be the cause.
Post #660805 31st Mar 2023 4:29pm
Bluestu33
Thanks!
I’ll check to coolant in the morning.
Would a coolant leak affect both front foot wells?
Post #660816 31st Mar 2023 8:10pm
Merchy
The water could collect in both foot wells, the insulation can also act as a wick and spread the water around. I only suggested the heater matrix as with the car under cover, the only water that should be in your car is the engine cooling water. This is on the presumption that the foot wells were dry before the car was parked under cover. As said, check the coolant level, if it's all gone, that's the source.
Post #660828 1st Apr 2023 8:08am
Bluestu33
Coolant seems fine and I’ve just run the car for half an hour and the footwells are still dry.
I took the car out in the run the other day, so I’m guessing it’s water ingress from somewhere.
Post #660836 1st Apr 2023 9:57am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Similar problem; not the sunroof, not the windscreen, not the footwells - so I’m hoping the bulkhead isn’t too bad…
Post #660863 1st Apr 2023 2:02pm
Merchy
All I can think of now is start trying to replicate the water ingress with a hose pipe / pressure washer and see what happens. With my L322 I once had an inch of water in the spare wheel well after the car had been standing for months, I tried EVERYTHING, but could not identify the leak, and it has never happened again. Still mystified to this day.
Post #660866 1st Apr 2023 2:22pm
DrRob
I never found my water ingress source. I just dried it out often Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660869 1st Apr 2023 3:16pm
