Home > Maintenance & Mods (L322) > heated steering wheel or paddle shifts
daveo
i am looking at an other mod to add paddle shifts to the pre touch screen but inorder for it to work you will loose your heated steering wheel, its a simple mod and works in the same way as two way lighting on your stairs in the house, now i am not saying you will end up with a light switch in your car but its the same idea,
the paddles will act in the same way as if you was pushing your gear lever up and down.
basically you would be tapping into the signal wires on your gear lever and extending them up to your steering wheel but you will loose you heated wheel as you will need to use this connection on the slip ring.
simon at powerful has some sets of the paddles at a very good price
http://www.powerfuluk.com/products/pdl322-...e-kit.html
this excellent link was given to me by dan,http://forums.bimmerforums.com/forum/showthread.php?t=1469408 its done on a bmw but as you know its almost the same, you dont need the smg slip ring as you will already have it if you have the heated wheel.
for me i will go for this as i dont use my heated wheel as i get the wife to go out to the car on very cold days and sit there holding the wheel for me to warm it, then i get dress and go a work. V8 facelift Range Rover Autobiography 22" wheels.
Post #66063 27th May 2011 4:30pm
daveo
Re: heated steering wheel or paddle shifts
Post #66064 27th May 2011 4:31pm
wiggs
Send the signal down via remote ...that way you dont loose the heated steering wheel
Post #66067 27th May 2011 5:44pm
daveo
do you have more info on this.. V8 facelift Range Rover Autobiography 22" wheels.
Post #66091 27th May 2011 10:19pm
wiggs
Have a look here http://www.disco3.co.uk/forum/topic46338.html
You may not need to modifiy the switches ..if they produce just an normal/open close state .
I am doing simular on a d4 ..but also using unused adaptive cruise control buttons to raise / lower the car from the steering wheel
Just waiting for the D4 to arrive though Sad
Post #66113 28th May 2011 9:22am
