![]() | Home > Maintenance & Mods (L405) > L405 3.0 v6 Transfer box |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2568 ![]() ![]() ![]() |
The double-flush is just a 2nd oil change. However it is only done in conjunction with a clutch re-calibration when there's been an issue with the clutch not releasing properly, with a common sympton of scrubbing tyres when cornerning slowly. |
Col-in-spain Member Since: 09 Mar 2023 Location: Javea Posts: 16 ![]() ![]() ![]() |
Thanks for the information. I am experiencing these symptoms and this is why I thought I would carry out a full oil change of both diffs and the transfer box. Do you know the full procedure for replacing the oil/flushing of the transfer box or where I could find it? |
I expect that the 2nd oil change wouldn't be necessary but if changing it a second time then run the engine to allow the remaining old oil to mix with the new oil then change it again. There isn''t a special procedure. Recalibrate after your final oil change. |
Thanks, I’ll give that a try and see if things improve. |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
Make sure you drive the vehicle after the first transfer box flush to mix the oil and new oil together. Then drain again.
Thanks, very informative.
You are welcome. I could not get Ravenol. It’s good oil. Pentosin is great too if you can find that. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
Thanks for your help. |
I finally got round to changing all the oils in the diffs and transfer box including the flush on the transfer box. All seems to be fine now, no scrubbing of tyres at low speed anymore 👍👍
