Home > Technical (L405) > Range rover p062e-11
FR motors
Austria 2016 Range Rover Vogue SDV8 Farallon Black
So I have a big problem
Rebuilded Motor
Keep getting code p062e-11 driver circuit performance
We rebuilded sdv 8 and First no start always Got short codes p062e and p062d (bank 2, bank 1 driver circuit performance).
All injectors was refurbished before puting them in and we were sure they work. Jokes on Us it was short on two injectors. Cylinder 2 and 6. So we started it and it lasted 10 min before dying. Open circuit injector 7 and p062e-11. Ok we bought New injector again. That fault never reapeered But engine keep dying and always code p063e-11.
We said Censored it abd bought 2 more injectors (now all 4 are New).
Next step was cable check. No visable problems But engine would sometime start sometime flutter like not all cylinders are firing. Sometimes would run super for few minutes.
So after checking all connections we tried connectors.
Cleaned it again and bend them a bit together.
Car runned for 20 min(no codes) . Started to build car together and second start also ca 20 min no problem(no codes) . Proceededvto put parts on it and on trd start after ca 15 min RR died Just same as before.
Ok surly connectors right?(bank 2)
Ordered New ones from usa and changed them.
No diference car never runs more than ca 2 min.
I Proceededvto to to change cables But couldnt get connectors for ecu side so I Just left 5-10cm old cables from ecu side and and connected New cables with new connectors on.
IT made absolutley no diference. Car still dies on ca 2 min and sometimes flutter on start and dies instantly(that IS the čase from begining)
So ok injectors New cables New connectors New. Now im thinking Ecm right... So it went to specialist. Got a call today that everything he could test on bench IS perfect.
So im getting crazy with this car questioninig all things.
Bank 1 IS where cylinder one IS right? It says cylinder 1passanger side(workschop manual) (steering wheel on left when sitting in car).
What else could be giving this error beside injectors, cables and ecm?
How should i process?
Thank you for help.
Post #660450 27th Mar 2023 8:06am
Jeck
Don’t suppose you ever got to the bottom of this problem?
I’m experiencing the exact same symptoms on a 2014 discovery 4, 3ltr diesel
Post #710970 3rd Feb 2025 8:44pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
See this link
may provide some answers. Also check the Disco4.co.uk forum for answers
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #711014 4th Feb 2025 11:28am
