![]() | Home > Maintenance & Mods (L405) > Solar Battery Trickle Chargers |
Max94L405 Member Since: 27 Jan 2023 Location: Hampshire Posts: 41 ![]() ![]() ![]() |
I was also looking into these for my ongoing battery drain you know about!
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
I bought an AA 4.8W model for about £40 https://www.ebay.co.uk/itm/233532721602. I checked it on my old battery in full sun at the beginning of the month and it was delivering around 300mA and it did charge the battery, slightly.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
In all honesty theyre a complete waste of money. You have seen it charging at 300mA in bright sun and clearly facing the sun. Once you move it behind glass which reduces the output by up to 50%, not be facing south, not at the best angles the output will plummet. The self discharge of a AGM battery is around 0.63 A/h per day. You need to be charging 24/7 at 27mA just to cover this loss, your panel will only be outputting it's peak rate for around 4 hours per day and very few days of the year. The current feeding the systems in the Range Rover will rapidly take above the output of this PV panel, it will do little to help your battery discharge. BMW i3 Electric Car
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 113 ![]() ![]() ![]() |
I use these on my seldom used cars and do a good job:-
