![]() | Home > Maintenance & Mods (L322) > Bevinsee H7 |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 43 ![]() ![]() ![]() |
Hi, I did just that couple of weeks ago, -07 TDV8, there´s a metal plate that locks the original bulb in place that you need to modify. I took some metal of with dremel so that the plate can be installed between the Bevinsee ring and chassis.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Straight fit on my 2011 so I guess there's some slight differences....although my LED bulb does sit at a slight angle off vertical. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 812 ![]() ![]() |
V45 series bulbs (H7 LEDs) is what i used
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
What did everyone do with the dongle/ballast thing attached to them?
As per Sam's video = push inside and screw the cap back on |
Ah, yeah, I found the video now, couldn't see it last night when I looked! |
