![]() | Home > Wheels & Tyres > Westminster 20" Alloys won't fit 2011 Vogue |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 176 ![]() ![]() ![]() |
There are 2 sizes of wheel nuts on a L322
Olaftheviking Member Since: 21 Mar 2023 Location: Surrey Posts: 9 ![]() ![]() ![]() |
Ah. Thank you.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
That’s odd because those 19” rims are the later type and Westminster rims are L322 run out rims of the last model - so in theory the nuts should be the same. It was the earlier BMW L322 to 2005 that had the different nuts. They changed at 2006 MY 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1307 ![]() ![]() ![]() |
I think you need LR173842 for the later wheels. |
Agreed, the nuts & lockers look the correct type for the wheels, check & measure the bore where the nuts go of the replacement wheels, they look a bit corroded on the back, possibly just need the oxidisation cleaning off? If you could remove one wheel nut and take a picture of it, you'll get a more definitive answer. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35654 ![]() ![]() |
check your original nut size using this pic, if they are he ones on the right then these nuts will fit the genuine westie wheels,
