Home > Technical (L322) > Inlet manifold
Page 2 of 3 <123>
Rudyard1
So…..all going ok so far but how in all that’s holy do you remove injector 4?!? There is a gnats whisker of clearance! Also same again for the engine mount - access is a pig!! 2007 Range Rover Vogue 3.6 TDV8
Post #659998 21st Mar 2023 9:19pm
Phoenix
Perseverance... standard tools will do it, there is no magic fix, I did use a small air ratchet on mine but a hand ratchet will work, just slower.
Post #660005 21st Mar 2023 10:41pm
Rudyard1
I’m thinking - if I loosen all the injector bolts, and inlet manifold bolts, would it just pull straight up and out?
Or do I have to remove all injectors first then manifold?
Who needs skin on knuckles anyway….? 2007 Range Rover Vogue 3.6 TDV8
Post #660063 22nd Mar 2023 7:56pm
Phoenix
Injectors first, they sit in the cylinder head by some distance so you can't 'cheat' them out by lifting with the manifold. Don't be tempted to split the rear one, it'll never work properly, despite what you may read on the internet....
Post #660065 22nd Mar 2023 8:05pm
Rudyard1
Thanks for this Phoenix - how much did you have to Jack the engine up? Also these parts - LR019118 - where do they fit?? 2007 Range Rover Vogue 3.6 TDV8
Post #660230 24th Mar 2023 12:09pm
james hester
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
I'm about to do the same to mine! does anyone have a part number for the injector seat seals?
I've looked at the fuel lines to the injectors and they are all in decent shape so I'm hoping I can get away with not coughing up an extra 90 quid per injector for the fitting kit.
I have part numbers for everything I need other than the seals (I think!)
got to fix the wife's Volvo first then jumping onto this. Let us know how it went.
Post #660252 24th Mar 2023 3:19pm
james hester
Post #660253 24th Mar 2023 3:19pm
Phoenix
Not an excessive amount, the engine mount needs about 50mm of separation from memory, the 'O' rings are to replace the ones on the injector leak-off pipe, the bit that pushes into the injector. Make sure you refit the 'R' clips to the injectors before you put the injectors back in the cylinder head.
@James Hester, you'll find a link on one of my posts on the previous page for the injector seals.
Post #660258 24th Mar 2023 3:37pm
james hester
Nice one thanks for that.
did you replace the cam cover gasket as well?
Post #660263 24th Mar 2023 3:58pm
Phoenix
The profile seal comes with the cover/inlet manifold, as does new fasteners.
Post #660273 24th Mar 2023 5:20pm
Rudyard1
All replaced and new fuel leak off line in. However it will not start - does anybody have any ideas to next step?
Engine will only turn over - however it will not fire!
Painful few days….. 2007 Range Rover Vogue 3.6 TDV8
Post #660885 1st Apr 2023 8:03pm
TDV8 Paul
When I did mine- the engine wouldn’t start for ages- to the point the battery died- assuming everything is connected- it seemed to take a little while to build fuel pressure sufficient enough to start it 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #661256 6th Apr 2023 7:44pm
Rudyard1
Well being the simpleton that I am, when cranking it over I started to smell diesel…….look underneath to see the oily stuff dripping on to the drive.
Covers back off, hvac plenum out again, leak off pipe shields out etc to see an injector not quite seated properly (fine mist/locomotive chuffing sound on idle) and a fuel feed pipe not quite tightened enough.
Did all that - all back together and boom. Engine start! And must say sounds very smooth!
I did have my ctek on it over night as the previous day I had nearly drained it.
I plan to do a very village idiot (me) style write up with pics etc and part codes. Stay tuned - and thanks again to all for the words of wisdom and shared knowledge - it has been invaluable. 2007 Range Rover Vogue 3.6 TDV8
Post #661284 7th Apr 2023 6:33am
TDV8 Paul
Glad you got it sorted!!! 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #661314 7th Apr 2023 2:05pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Good you got it sorted with a positive outcome. I look forward to reading your full write-up with pics 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #661335 8th Apr 2023 6:35am
Page 2 of 3 <123>
