Home > Maintenance & Mods (L322) > Vibration at speed
this_is_anarchie
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Vibration at speed
Hi all,
My L322 TDV8 has a vibration at most speeds, worse when braking. Do we have any ideas what could cause it? it doesn't do it stationary and i am fairly confident it isnt gearbox.
Any ideas?
Thanks Range Rover Vogue SE 3.6 TDV8
Post #659562 16th Mar 2023 3:54pm
DrRob
Check wheel balance x4
Check for calipers sticking (use a hand held laser thermometer) x4
Check for disc warping (garages have run out gauges) x4
Keep us posted... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #659604 17th Mar 2023 7:25am
kevinp
Wheel nuts tight enough.
Bulges in tyres.
How old are the tyres?
Post #659605 17th Mar 2023 8:15am
this_is_anarchie
Rear tyres had flat spots so have been replaced, but car is still shaking. Garage said prop shaft bearing is beginning to wear, could this be it?
Could it be gearbox judder?
Post #659972 21st Mar 2023 3:00pm
DrRob
Propshaft bearing is an easy swap out on a 3.6 tdv8.
May as well try it for £75 Thumbs Up
https://www.advancedfactors.co.uk/toq00005...6451-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #659985 21st Mar 2023 6:21pm
