Home > Maintenance & Mods (L322) > Garage dimensions for 2009-2012 L322
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
Hi all and hope you are well........
Garage door being fitted soon to make it wider overall.
The full dimensions of the garage are:
Access width 90" (2300mm)
Width inside 125" (3175mm)
length 198.5" (5040mm)
Interested to know your single garage dimensions, how does it compare, and will a L322 fit in my garage?
Steve
Post #659557 16th Mar 2023 3:11pm
this is from the owners manual [download link in the wiki]
Post #659559 16th Mar 2023 3:16pm
Baltic Blue
Yes your L322 will fit in (assuming you have sufficient height clearance ) and don’t forget that up and over garage doors reduce the clearance.
I recently moved into a new built house and was lucky enough to get the builder to add a couple of extra courses of bricks before adding the roof, and to reduce the pillar size to allow me to have an 8 ft square up and over door. It’s 6m x3 m inside dimension and I have been able to build a 600mm width workbench across the full width and still fit my L322 in.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #659593 16th Mar 2023 9:24pm
EOD Steve
Hey guys thanks for your replies.
New door is a sectional, and will be higher than the existing up and over. Seems as if the 317cm internal width is on the larger size (for a single) so that cool.
Great pics mate and very useful indeed.
Thank you !!
s
Post #659594 16th Mar 2023 9:37pm
Baltic Blue
Also you may want to know you need 2m 62 height clearance to put the bonnet in service mode with the car at normal height. Thumbs Up
Post #659596 16th Mar 2023 9:51pm
EOD Steve
Sounds like a job for my local LR indy, about 500 yds away luckily !!!!!
s
Post #659598 16th Mar 2023 9:55pm
