Home > Technical (L322) > L322 3.6 TDV8 Oil leak and Engine system Fault , ohh nooooo
Bogi 6357
Hi
I have a model year 2008 , L322 TDV8 Vogue , which had turbos done at 112,000, I am now on 143,000 miles and have an oil leak that is coming from both sides of the engine , but from above the turbos can see where it’s coming from , and oil level on dip stick is where it should be !
I’ve always had the historic egr codes on the which were blanked off etc , and just turn the light off when time for mot ,
The car has a new battery about 3 months ago when I replaced the starter etc , I have attached the codes for the egr pre getting the engine system fault , and have also attached the print out of codes now present with the engine system fault , I’ve checked hoses can’t see anything untoward , but notice that on start up that I don’t hear the actuators sweep a few times and same on switching off , wondering if anyone can help pinpoint from the codes what could be happening ,
Cheers Ian
Post #659491 15th Mar 2023 7:51pm
Bogi 6357
Update to above
All sorted , drivers side turbo actuator had given up , not stuck or seized , the motor had packed up , also had a bit of burnt wiring ,
Both turbos had been replaced shortly after I got it , oil leak from banjo bolt possibly done something to wires or connector , can’t see where else oil would have come from
Actuator replaced with a working second hand one
Cheers
Ian
Post #663444 4th May 2023 6:01pm
Sandyt
Well done very satisfying when a problem is resolved Thumbs Up
Post #663448 4th May 2023 6:51pm
