Home > Technical (L405) > Coolant leak info required
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Evening, Technical is locked for some reason, i have been fitting the new front knuckle to my L405 ( replaceing the side that didnt collapse) on my way into the shop this mornng i got a coolant level warning, with the car up on the ramp i could see the drivers side rear of the undertray had red coolant puddles in it, looks like one if the pipes are leaking, so looking up on the Rave manual, but i dont see them, any one know what they are called, they appear to go to the gear box, but the transmission cooler pipes cary oil and are the passenger side, im not sure what they are for, ran out of time to get the bash plate off to look further, just wondering if anyone can shed some light on the purpose of coolant pipes under the front drivers footwell area?? Cheers Pat SDV8 2015
Post #659488 15th Mar 2023 5:59pm
fisha
Do you have rear climate control ?
The rear stuff has its own hevac unit which is supplied by hot coolant pipes that run from front to rear on the drivers side. If you do a bit more searching, you'll find some threads about the pipes as they have been known to corrode in places. It might be those pipes ? V8 or else ...
Post #659660 17th Mar 2023 4:57pm
fenair
Top man, yes i do... it kind of came to me ths mornig that would be the only logical reason for coolant there, my intial thoughts was that there may have been some diesel warming system , hence why i posted , but then in teh light of day the penney dropped, im going to get under it tomorrow and investigate futher..
Thanks mate
Regards
Pat SDV8 2015
Post #659666 17th Mar 2023 6:24pm
IIRC Replacing the pipes with genuine is a huge job, apparently a lot has to be removed to replace the original pipe, some have just used a rubber pipe and rerouted it to save all the dismantling... Thumbs Up Pete
Post #659688 17th Mar 2023 9:59pm
fenair
Thanks Pete, I suspect that would be the case, hopefully the diameter will be a size we use for AC hard lines,then I can do a repair section rather than replace, I will do a post if possible.
Pat SDV8 2015
Post #659690 17th Mar 2023 10:12pm
