Home > Maintenance & Mods (L322) > Do I just hit it with a bigger hammer?
supershuttle
Trying to get the tow bar off, all looks very simple std LR stuff, box section arm plugging into square socket. Removed the pin and started trying to shift it with a lump hammer - didn't budge.
Should I
a. Get a bigger hammer.
b. Try and pull something heavy with pin removed.
c. look again and see that I need to remove something else.
Tried to search but tow bar is tedious in the number of results it returns. Geoff
Post #65935 26th May 2011 6:58pm
a.
Post #65936 26th May 2011 7:01pm
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
Try some penetrating fluid or WD40 then
a.
Post #65939 26th May 2011 7:16pm
AMD
Take the pin out, tie a rope to the ball and the other end to a tree and put your foot down...please send video so we can see which bit came out Wink Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #65940 26th May 2011 7:17pm
dan_uk_1984
Letsavit has a tree you can pull out.
Post #65941 26th May 2011 7:19pm
mzplcg
I'd go with D.
Rope tied to something solid. Slightly tension it by pulling forward. Then clout it once it's under tension.
If you have to do option B then use a chain. Ropes can and will snap under shock load and I'd bet good money when it does the recoil will leave its mark on your tailgate. Call it Sod's Law if you like. Laughing
Post #65942 26th May 2011 7:35pm
He's to scared! Whistle
You just need a BFH!
Post #65943 26th May 2011 7:36pm
stu
you could also put some gentle heat on it. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65949 26th May 2011 8:34pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Duck oil or diesel over night.
Tap it off once lubed Cool 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #65951 26th May 2011 9:05pm
Mine is also corroded in, I've used penetrating oil, heat, chain round a tree and whilst the tension was on I placed a 20 ton bottle jack between the ball plate and the bar......and it's still seized solid.
The only way to remove it will be to remove the complete tow bar to gain access to the rear of the square, then apply heat and using an air hammer rattle it out.
Post #65953 26th May 2011 9:17pm
elpeede
Thats what I thought too when I removed mine... the next size up hammer will work.
Don't worry, they are made of stern stuff. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #65962 26th May 2011 10:15pm
The "Adjustable" spanner as we call it. Lol
Post #65968 26th May 2011 10:32pm
nbunney
Is it the swan neck or fixed plate?
Why do you want to remove it?
Post #65991 27th May 2011 9:12am
supershuttle
It's fixed plate, I would like to remove it because I should be able to remove it and I'll need to if I get my hands on the official LR bike rack Smile
When I've got it off I'll grease everthing up so it will slip in and out easily in the future - oh err......... Whistle
I'll give it a "proper go" this weekend! Geoff
Post #65997 27th May 2011 9:42am
Just make sure you don't give your rear bumper a "facelift" with the extra gusto!
Post #66004 27th May 2011 10:37am
