![]() | Home > Technical (L405) > L405 V6 supercharge communication module problem or ? |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 255 ![]() ![]() ![]() |
Have you checked the main earth under the front section of the O/S/F wheel arch liner. Quite common and can cause all of the faults listed.
flossington Member Since: 12 Jan 2023 Location: houston Posts: 2 ![]() ![]() ![]() |
thank you for your response....im going to check it this weekend.....do u have any advice on what to look for.... |
There's an earth mounting post that have a habit of shearing off from the chassis due to galvanic corrosion, the post comes away with all the earth cables still attached, hence loads of faults due to losing earth to many ecu's. Its mounted just by one of the accelerometers, should be obvious once you remove the wheel arch liner. There's one on the nearside too, if one has failed you can bet the other won't be far behind.
