Home > Technical (L405) > L405 suspension height settings
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Evening, as some may be aware, my front knuckle snapped last Saturday,so today I have fitted new nuckle and also drive shaft and lower arms. After a drive the car sits high both sides at the front, with a noticeable difference in air gap between front and rear arches.
I have the gap iid tool and can calibrate the EAS , but searching the net I can't find the dimensions relating to the 405 model.
Dose anyone happen to know the distance measurement for front and rear please?
Thanks in advance
PAT SDV8 2015
Post #659147 11th Mar 2023 8:57pm
MarianaWestminster
Hi Fenair,
According to the workshop manual the heights when measured with the vehicle unladen are 471mm at the front and 468mm at the rear.
This is measured from the center of the wheel to the edge of the wheel arch (not the wheel arch liner)
Information gathered from the WSM see screenshot below:
Hope this helps!
Post #659151 11th Mar 2023 9:27pm
fenair
Superstar, many thanks, appreciated.
Have a great weekend
Pat SDV8 2015
Post #659152 11th Mar 2023 9:30pm
MarianaWestminster
Your welcome, hope you get it figured out!
Thank you and same to you. Just hoping for no more snow overnight so I can clean my interior tomorrow!
Post #659153 11th Mar 2023 9:35pm
fenair
😂👍 SDV8 2015
Post #659154 11th Mar 2023 9:36pm
