Home > Maintenance & Mods (L405) > That’ll be a coolant leak then… |
swissomatic Member Since: 16 Feb 2016 Location: Charleston SC Posts: 46 |
My guess is that it’s the crossover coolant pipe at back of supercharger. If your vehicle is a 5 litre V8. Known weakness on pre 2017 (I think). |
7th Mar 2023 9:55pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
The OP drives a 4.4TDV8 sir... |
7th Mar 2023 11:09pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
So I’ve bought a bore scope off amazon which arrived today which I’ll try later on ( maybe when it’s less cold in the dark ! ). I figured that reading the talk of brittle pipes when pulling things apart, I would want to do as much as I could with things in situ to try and find the leak, and only then once I have the part make effort to replace. V8 or else ... |
8th Mar 2023 9:05pm |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 |
I've had a similar issue and it was the thermostat housing LR036058 and the upper water outlet LR111459. The parts are on back order and have been for four months. Rumour has it they'll be available end of May.
9th Mar 2023 1:14pm |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
I’ve tried, North American, and South Africa as well for those 2 parts , no chance !!
9th Mar 2023 1:37pm |
I was lucky insofar as they didn’t actually strip the leaky part. My cars taking about a cupful a month. I’m told the likelihood is that it’s just an O ring but LR won’t repair and need to chuck £200 worth of plastic at it. |
9th Mar 2023 1:55pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1424 |
@Huwrhys:
9th Mar 2023 2:06pm |
It's £750 for LR to do it but I've had it authorised by the Ext Warranty.
9th Mar 2023 2:15pm |
I’ve saved more than 200 quid in fuel already, I’ll be well off come May
9th Mar 2023 4:38pm |
I also have the use of my wife's Fiat 500, same issue with the twin axle.
9th Mar 2023 4:45pm |
No its, all fine. Similar thoughts. Although I thought the thermostat was at the front half of the V, and its not obvious that its leaking from there, I cant see any UV stains below it or around it that are anything like as obvious as the picture of it running down the back. V8 or else ... |
9th Mar 2023 10:15pm |
I know, I thought the same but they described my leak as running over the transmission. I’m not sure they know what the hell they’re doing tbh. |
9th Mar 2023 11:15pm |
Having dropped my car in over a month ago to have two hoses replaced, one from the reservoir and the other one missed diagnosed as being near the oil cooler. The car was returned without an operational heater which had been working perfectly well beforehand. It’s been back to the main dealers twice now to get the heater working and despite having vacuum filled the cooling system, the heater is still not working. Does anyone have any thoughts, the main dealer say that because I have a very minor leak in the thermostat housing they can’t fill the system entirely, does this sound reasonable to you? I have to say I’ve been arguing it for some time now. |
11th Mar 2023 9:39am |
