Home > Maintenance & Mods (L322) > Advice, replacing rear pads 2011 vogue
GTTURBO87UK
I need advice on changing my rear pads if any can help?
Are these just the same to replace as any other car or are they slightly different due to the electric park brake. It all looks just normal to me but the piston on the calliper needs quite a bit of encouragement pushing in. Just thought I would ask someone before pushing it in as I don’t want to damage anything. I haven’t done brake’s before on cars with electric park brake. It’s a 2011 4.4tdvd vogue.
Post #658884 8th Mar 2023 6:44pm
JayGee
It’s a simple single piston on sliding pins but the piston and pins can seize and it’s not uncommon to have to replace them when you do the pads and disks. The EPB is a separate system inside the of the disk ‘bell’
Most of the braking work is done on the fronts on the L322 esp the 4.4 with it’s bigger front brake setup so the rears don’t get a lot of use and hence the seizing issues. 2012 TDV8 Vogue (L322)
Post #658886 8th Mar 2023 7:01pm
GTTURBO87UK
Ok that’s great thanks. I thought the handbrake might have been there.
Post #658890 8th Mar 2023 7:34pm
DrRob
I’ve just replaced my rear calipers with new TRW ones (OEM) from Advanced Factors (site sponsor discount) as old ones (original probably) were shot. Cheap enough not to warrant refurb. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658905 8th Mar 2023 9:07pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Pads are the same as old school just like the shoes in the drum. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #658909 8th Mar 2023 9:56pm
