Home > Maintenance & Mods (L322) > service components |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Easy DIY jobs …
7th Mar 2023 7:53pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Who did the last service? Clearly not reset the service interval by sound of it Needs doing as the DPF uses it to calculate stuff once oil is changed. Oil dilution calculations etc.
7th Mar 2023 9:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
If you have owned it for a year? Could this be the service counter simply clicking over 365 days since it was last reset? By the last service technician? I'm assuming you didn't reset the counter when the engine service was carried out? |
7th Mar 2023 11:15pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
A brake fluid flush due to the age of the car would be a good idea but it's not a straightforward DIY job ( do a search on the forum) especially if the front bleed screws are seized in the callipers through galvanic corrosion. Any preventative rust protection is worthwhile if you are keeping the car but probably best done in the warmer months. 2012 TDV8 Vogue (L322) |
8th Mar 2023 9:02am |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 139 |
Thanks everyone, all useful comments.
8th Mar 2023 7:48pm |
MAPT is Manifold absolute pressure and temperature sensor.
8th Mar 2023 8:22pm |
AFAIK It’s just pressure ‘MAP’ - the IAT ( intake air temperature) is a separate sensor infront of the throttle plate and egr inlet which stays clean 2012 TDV8 Vogue (L322) |
8th Mar 2023 8:50pm |
Extract from Workshop Manual.
8th Mar 2023 9:02pm |
Logically temp data is needed in the plenum as EGR gasses are being added. 2012 TDV8 Vogue (L322) |
8th Mar 2023 9:24pm |
