Home > Maintenance & Mods (L322) > Height Sensor fault
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Height Sensor fault
Evening all. I have just started to get a bong when starting and the yellow ‘Suspension Fault’ message. Ran the IID and got the attached message. There was another fault message that cleared something like height sensor physically inoperative or out of alignment but that cleared. This only started after I jet washed the arches on Wednesday. Is it time for a new height sensor?
Thanks
 Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658557 5th Mar 2023 5:45pm
Goldstar
Just checked the live values, 5 ish volts going in, 0 volts output so am I right in thinking that the sensor has failed?
Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658609 6th Mar 2023 10:34am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Sensor or damaged broken signal wire from the sensor back to the ecu. Just had this on my L405, broken signal wire; much tracing later and found a damaged wire in the loom just below o/s/f headlight.
Sensor signal should be between 1.2v - 4.8v (though extents of wheel travel).
Good luck L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #658622 6th Mar 2023 11:42am
Goldstar
Thanks - I'll have a trace of the wires into the car first and see what I can find, if anything. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658624 6th Mar 2023 11:47am
