![]() | Home > Technical (L322) > Fitting /re-fitting front driveshaft |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Not sure with everything still in place, I had removed the entire strut, everything, the reason I started the job was to replace the wheel bearing which was failing, I ended up replacing most parts, then the same on the other side.
RobL322 Member Since: 29 Sep 2021 Location: Yorkshire Posts: 32 ![]() ![]() |
ROM Get to friendly garage soon, that needs to be popped back in. Had any work done recently in this area? best case scenario. Maybe the driveshaft was never properly re-installed and just needs pushing home. worst case scenario. The circlip is no longer present. 2004 L322 BMW 4.4v8 petrol/lpg 2006 m139 QPv 2001 3200GT 2001 mx-5 2001 728iL 1967 Rover 2000TC |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
I had the same problems with my OSF driveshaft last year. The boot split on my original shaft at the hub end and I decided that as it was the original driveshaft, I'd buy a new one from site sponsor AF - not an original part but OEM.
