![]() | Home > Technical (L322) > Servo loosing vacuum overnight |
Not specific to L322's, I have seen leaks around the master cylinder 'O' ring and the pedal actuator rod seal, I usually smoke test them. If the non-return valve is passing, then a vacuum gauge on the end of the pipe will show that reasonably quickly |
Gave the connector to the servo a 'wiggle' the other day and since then it's not lost vac overnight. I should pull it out and put some silicone grease on it to effect a better seal but don't want to risk snapping another old bit of plastic so will leave it alone unless it happens again. 2012 TDV8 Vogue (L322) |
