Home > Technical (L322) > Terrafirma Front Discs
paul70
Anyone had any experience with Terrafirma front brake discs, are they any good?
Spotted them for sale at a good price from Maltings Off Road which, I'm sure as a supplier, have had good reviews on here.
Regards
Paul
Post #657875 26th Feb 2023 5:58pm
I used the drilled ones on fatty off roader, they clear mud quicker than solid discs...
Worked well, couldn't tell the difference to normal ones, I think pads have a bigger impact on braking than discs.. Thumbs Up Pete
Post #657894 26th Feb 2023 7:10pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I’ve got some on the front of the Landy - they seem fine. Maltings are a decent supplier.
Post #657940 27th Feb 2023 12:30am
paul70
Thanks both I'll get my order in today.
Paul
Post #657971 27th Feb 2023 1:59pm
JayGee
The genuine ones are not that expensive and likley to be better balanced for road use (there is a lot of rotating mass on the fronts). Most of the braking is done on the fronts and I'd not want to compromise on these personally. Also Grooved / vented disks are classed as a modification so you will need to inform your insurer. 2012 TDV8 Vogue (L322)
Post #657973 27th Feb 2023 2:15pm
Grooved has always been noisy on ffrr from my experience... Thumbs Up
Post #657978 27th Feb 2023 3:20pm
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Ive got drilled and grooved discs all round on my TDV8 4.4. They work well however they are a bit noisier than standard and (in my case ) you can feel them through the brake peddle.
Im about to replace all my brakes and will be returning to factory discs when I do. 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #657994 27th Feb 2023 5:15pm
JoolsB
I went for Brembo on the FF, but happy to go aftermarket on the defender. In my view, the decision to go OEMor pattern depends on things like what it’s for and how much the car is worth. I’ve got a CLK that I gave 4,000 for - when I did the brakes I opted against paying MB 450 for the privilege and put TRW discs on for around 110. My fatty however is under 90,000 and with a FSH so it’s worth spending a bit more on.
Post #657998 27th Feb 2023 6:14pm
paul70
Thanks all for your advice.
Paul.
Post #657999 27th Feb 2023 6:19pm
JayGee
Grooves and holes on disks are there for a specific purpose which is not required in normal road use and may infect result in inferior performance in an emergency stop road situation. 2012 TDV8 Vogue (L322)
Post #658000 27th Feb 2023 6:25pm
Jases4x4
United Kingdom 2010 Range Rover HSE TDV8 Santorini Black
I have got these on my l320 from maltings also, I did a google search of noisy terrafirma discs to see if anyone else had squealing brakes, Mine are paired with ebc yellowstuff pads and have done over 500 miles on newly refurbished 6 pot brembos, These alot of black dust on the discs, I think its the discs but not certain, What would everyone think is causing the horrendous squealing when braking?
Post #663681 8th May 2023 9:52pm
p38arover
Australia
That sounds like marketing speak. Every disc that I’ve fitted to my Rangies has been machined (turned) on all surfaces so I can’t see that they’d be less balanced than genuine discs. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #663682 8th May 2023 10:12pm
JayGee
https://www.fullfatrr.com/forum/topic63600.html
Drilled and grooved disks for a road car - now that's marketing 2012 TDV8 Vogue (L322)
Post #663688 9th May 2023 6:37am
