Home > Technical (L322) > Knocking noise rear |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 |
So replaced the shocks with bilstein ones and as before the ride is still lumpy and knocking noise still there has improved slightly but not much. Still getting the thumping noise from dead stop then driving off. Still a problem any help? |
9th Feb 2023 6:16pm |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
Have a similar clunk from the rear suspension, think its more noticeable from the rear left. And maybe also a harshness to the rear suspension in general.
26th Feb 2023 12:19pm |
What is a/the donut? 2011 Vogue SE 4.4 TDV8 |
26th Feb 2023 12:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
He is referring to the centre propshaft bearing, on a lot of older cars it's a donut, on the fatty it's a bearing... Pete
26th Feb 2023 7:27pm |
Hey deejay with how you have described it is almost exactly what I’ve got now although it will happen sometimes then nothing. So I’m guessing it must be coming from the rear passenger driveshaft considering I’ve changed the rear propshaft and the donut so can’t be that. But I’ve jacked up the rear wheels and spun the tyres and didn’t get any knocking noise |
28th Feb 2023 10:11pm |
Grizzly Member Since: 01 Oct 2021 Location: Cheshire Posts: 5 |
Did you end up fixing this problem? What did it end up being?
30th Oct 2024 4:51pm |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 |
Have a look at post number 7 from this thread on Rangerovers.net
31st Oct 2024 12:20am |
Thanks,
31st Oct 2024 8:38am |
Those tyre pressures you refer to are not correct.
31st Oct 2024 8:45am |
Yes, it currently doesn't have the spare in the back. I have tried 33 front and 36 rear but it made no difference, i have always put 33 in all four and after 14 years running this thing it's only started making the noise 3 weeks ago, but i will put 36 back in it just to eliminate it.
31st Oct 2024 10:57am |
