![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Top coolant pipe snapped the other connector… |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I finally managed to get around to tackling the engine squeal I’ve had for far too long…
I instead ham fisted the other bloody end! ![]()
I’ve tried to remove the pipe inside the top cooler hose and should be able to in time (the broken part inside is brittle), however i need to replace the connector at the other end.
As far as i can tell it is from the Thermostat housing top outlet, which i can buy for around £60 (LR022690). However, the connector is behind a clip suggesting i can simply replace that? If so, does anyone know where i can find one? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
So I am a little closer to what i need.
The part circled in green is what I need but there is no reference that i can find to its part number or correct description. The pipe it attaches to doesnt seem to come with it. So I am still a little stuck here… Hoping someone knows where i can get that part from… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
I think you'll find the whole assembly needs to be purchased (8592A), that's what I did for mine.
Cheers guys for the feedback. Indeed the assembly unit doesn’t appear to be available. Very frustrating.
Something along these lines if the hose sizes are correct.
Cheers for that rjff
My intention was to use the existing female with the new male, and you 2nd link with the elbow looks to be the right size to do just that …and if not I can at least replace my current female with the new one! By my measurements the current male is between 7-9mm (inner to outer measurement) so assume that’s classed as an 8mm connector. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Just spotted that 9.89 is printed on my current connector which is the same as your link |
Bit of brass or Ali tube and some jubilee clips would seem to be a practical replacement for that bit of plastic 2012 TDV8 Vogue (L322) |
I hope that works, if it does great. Let us know. Cheers
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i had the same issue and replced it with this
As requested (albeit later than intended) the replacement clip worked perfectly! The only minor difference is the double disc of the original (which clips into a bracket) vs the single disc of the new one… but if you leave a slight gap where the hose meets the disc it slips into the bracket. All in all a quick and cheap replacement ![]() This…
Vs this…
Cheers jayk69. Another simple fix, however I prefer the flip method I used simply to allow me to remove the top pipe without issue in the future. Especially if the plastic get brittle over time and decides to snap when needing to separate it! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
im pretty sure I've seen this part used by others... check actual sizes, i guessed 1/4 pcl... its common on car workshop airlines. and easy to buy on eBay too. you screw in the male to the main body, and warm the plastic pipe and slide over the other end
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
Just to confirm that the correct size of the connector is this:
