Home > Off Topic - Other Cars > Weird battery issue...
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
My friends Peugeot van wouldn't start yesterday. This morning i tested the battery with my multimeter and it showed 12.9 V, but just a single click on turning they key.
Popped by starter pack on and it fired up, while running was showing 15v.
So why would it show good volts but just click? Would a knackered cell do that?
Thanks!
Post #657673 24th Feb 2023 7:11pm
Dan_Veluwe
Netherlands
Check the earth lead, how old is the car ? Can the lead to the engine be corroded ? I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
PHEV P400e Hybrid Autobiography Loire blue= SOLD
D5 SD4 HSE Lux Corris grey = SOLD
D3 TdV6 HSE Lux Vienna Green =SOLD
P300 F-Type 2018 Ultra Blue = SOLD
25t F-Pace 2020 Loire Blue = SOLD
Post #657674 24th Feb 2023 7:16pm
philip1972
Car is a 2020 van, couldn’t see any corrosion but I will have a proper look tomorrow.
Thanks 👍
Post #657675 24th Feb 2023 7:19pm
Phoenix
It could be the battery, corroded connectors (remember the battery pack goes on the outside, the vehicle battery goes on the inside) or the starter drawing more current than the battery can provide by itself.
Test 1 measure battery voltage at the battery clamps when attempting to crank.
Test 2 measure battery voltage at the battery posts when attempting to crank
Test 3 measure voltage between the -ve battery clamp & a good ground point on the engine when attempting to crank.
You may well see the issue if the weather is cold enough for the glow plugs to draw enough current to show a low voltage (<10.5VDC) on any of the above tests.
Post #657678 24th Feb 2023 7:28pm
philip1972
Great, thanks for the advice.
Post #657683 24th Feb 2023 7:47pm
