Home > Maintenance & Mods (L322) > Bushes for Rear Anti roll bar (aka sway bar)
Buckie1967
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Buckingham Blue
I require RBX500160 bushes x 2 for my front sway bar.
My rear sway bar is AH42-5A771-AA but apparently LR never sold the bushes for the rear sway bar.
Has anyone sourced them or are the front bushes suitable for the rears?
Thanks.
Post #657636 24th Feb 2023 12:49pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
A quick Google of that part number provides numerous suppliers including Rimmers and JLR Classic, so I don't know why you'd have any issues getting hold of them.
ETA: That part number appears to be associated to the B6 Armoured version - are you sure that's what you're after? 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #657637 24th Feb 2023 1:05pm
Mikey
RBX500160 is the number for the front ARB bushes for an armoured L322
RBX500040 is the number for the rear bushes for an armoured L322. If the fronts fitted OK, then it stands to reason that the rears will be the same (but I'm not 100% sure. Not an issue I've ever come across)
Post #657639 24th Feb 2023 1:07pm
Danb_220_2019
Further note, Powerflex supply bushes to fit front and rear anti roll bars on the L322.
FRONT:
https://powerflexstore.co.uk/land-rover/ra...32-803-31/
REAR:
https://powerflexstore.co.uk/land-rover/ra...-813-26-5/ 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #657640 24th Feb 2023 1:11pm
JayGee
Try powerflex also. 2012 TDV8 Vogue (L322)
Post #657641 24th Feb 2023 1:12pm
Buckie1967
Thanks for the responses.
I have sourced some which hopefully will be suitable for the fronts and they have a 31.0 mm internal diameter so if that Powerflex info is correct then I am hopeful they will fit.
The question was really more specific to the rears as my reference diagram (from Advanced Factors) state these bushes are not sold separately and therefore do not supply a code for them.
The powerflex info shows the rears to have a smaller internal diameter (26.5mm) so chances are the fronts won't fit the rears and I need to source an aftermarket pair since LR don't sell them.
Post #657645 24th Feb 2023 2:30pm
Buckie1967
It appears the front sway bar changed at some point but the bushes for it remained the same.....RBX500160 which I understand have a 31.0mm internal diameter.
Post #657646 24th Feb 2023 2:41pm
Buckie1967
RBX500040 for rears Thumbs Up
Post #657651 24th Feb 2023 3:05pm
Buckie1967
Post #658131 28th Feb 2023 10:14pm
Buckie1967
I just acquired a used front and used rear sway bar. Word of warning....these sway bars change slightly from early L322's to later models.
I managed to remove the original bushes but for anyone looking to do this job it is a PITA as they are bonded onto the swaybar.
It was hard enough getting them off and I had the bars clamped in a vice.....I really don't think this can be done whilst the bars are still on the vehicle but hats off to anyone that's done it before.
I am going to get the bars shot blasted and powder coated and aim to fix to the vehicle in due course.
Post #658132 28th Feb 2023 10:24pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, resurecting this old thread as replaced my rear anti roll bars yesterday being as I'd had them sat on the shelf a while now waiting for better weather.
Jeez what a nightmare, they'd literally fused themselves to the bar, had to cut them off slice at a time working around the bar with a reprocating saw, both the same.
Once I got that all off had to then use a shapened scraper to remove the rest, finally some emery banding to clean back to metal.
3 hours, thankfully don't have to do that again for a while
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684713 4th Feb 2024 11:11am
mgrover
AndyRoo, how are they with time on the car now?
Any issues or knocking?
Also did you add any lubricant anywhere?
Cheers Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #693020 20th May 2024 9:25am
