Home > Maintenance & Mods (L322) > OAT Antifreeze
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
OAT Antifreeze
Just after a bit of advice and owners experience on anti freeze, will soon be doing a coolant change on my 2010 3.6 TDV8 and was going to go for OAT concentrate from a well know motoring shop. Its got the pink stuff in already so guessing its OAT in there currently, was going to drain and flush and then add OAT 50/50 mix.
I'm sure this will be ok as I will be flushing the old stuff out, plan to just undo the rad bottom hose and remember to put the heater controls to hot and remove expansion lid.
Any advice welcome.
Post #657594 23rd Feb 2023 6:15pm
Phoenix
Point 1 - what are you going to flush it with?
point 2 - you'll never get all the old coolant out, the best you can hope for is to dilute it with fresh so personally I'd drain & vac fill with concentrated stuff on the basis that the old coolant will dilute it by ~30-40%
Confusingly, there are several types of OAT coolant, I think the correct one is G30.
Post #657596 23rd Feb 2023 6:20pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
https://gmb.net/blog/inorganic-vs-organic-coolants/
Post #657614 23rd Feb 2023 11:22pm
tj196443
Thanks for the advice much appreciated
I was planning to flush a couple of times with clean water to try and neutralise what will be left in.
Post #657723 25th Feb 2023 11:09am
Phoenix
Don't flush or mix with tap water - especially if 'hard' water, coolant systems should be flushed either with pre-mixed coolant or de-ionised water, dilution should also be with de-ionised water.
Having said that, I've only worked in one dealership that used de-ionised water... and it wasn't JLR.
Post #657797 25th Feb 2023 6:53pm
Notyalc
Agreed, always use de ionised water. Easily available in 20L containers.
Post #657840 26th Feb 2023 10:16am
