Home > In Car Electronics (L322) > Can you delete a phone from the car (2012)?
JW911
As per the title.
I want to delete my phone from the car and reinstall it and not sure how to do it.
Note: This is not deleting the car from the phone…. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #657509 22nd Feb 2023 11:31pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
The car doesn't store the phone. It is 'deleted' every time you switch off and/or walk away from the car. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #657530 23rd Feb 2023 10:19am
JW911
Thanks. Still in a quest to get my phonebook back. 2021 3.0 P400 Vogue
Post #657542 23rd Feb 2023 12:05pm
mjdronfield
Looks like you have to maybe connect a load of other devices to be given option to remove one.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #657553 23rd Feb 2023 1:01pm
JMC
The car only has access to the phonebook stored in the phone when the phone has a live connection via bluetooth. Once the bluetooth connection is lost, the car doesn't keep the phonebook, but it's obviously still in the phone!
Whenever you start the car, set the car screen to Phone and you will see the phonebook and call lists are 'greyed out' to begin with. After a minute or so, the screen buttons become accessible, because the car has loaded the data via the bluetooth connection. However, once the bluetooth connection is terminated (by switching off the ignition or turning off the phone) the data is not retained by the car. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #657584 23rd Feb 2023 5:46pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Perhaps not applicable but have you checked that your phone is set to ‘sync contacts’ with the car?
On an iPhone it’s in settings, Bluetooth, Land Rover then make sure that ‘sync contacts’ is switched on.
I had this turn itself off a couple of times when I did an iOS update.
Just a thought Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #657586 23rd Feb 2023 6:02pm
JW911
I’ve done all of the above (an earlier thread refers). The phonebook disappeared halfway through a drive. Something threw a wobbly and I haven’t seen it since. Everything else works normally.
Looks like I’ll have to pair another few phones…. 2021 3.0 P400 Vogue
Post #657593 23rd Feb 2023 7:14pm
