Home > Technical (L322) > 2007 FBH Remote Battery Drain |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1180 |
Just a thought, did you buy a multi pack of the button cell batteries? I did that a while back to renew my car key batteries. Turns out the batteries must have been nearly dead when purchased, bought some more and that solved the problem. Otherwise, open up the remote and inspect / check / clean with contact cleaner and try again.
13th Feb 2023 4:08am |
yomchi86 Member Since: 22 Nov 2022 Location: Leeds Posts: 11 |
It was indeed a multi-pack (of 2, and I bought x2 packs so potentially separate). Could be a dodgy batch though in fairness, I'll get the multimeter on the replacement batteries and see if they are good from the get go. The batteries for the FBH remote I have are CR123A.
14th Feb 2023 11:40am |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 63 |
Mine would indicate bad battery. Changed battery, same issue next day. Turned out the battery wasn't making good contact in the remote. Try to carefully bend the central contact up. Scrape both contacts with a sharp tool. |
22nd Feb 2023 5:56pm |
Thank you I did exactly that, contact cleaner and scraping any dirt off the terminal contacts as well as pulling the contacts out a little bit to ensure a more secure fit for the battery. With the weather picking up I've not had to use the FBH so not checked the battery for a little while. Hopefully that's solved the issue.
22nd Feb 2023 9:08pm |
