Home > Technical (L322) > 2006 4.2 SC Air suspension issues
Cosmin
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Gentlemen,
My RR's suspension is dropping over a 4,5 day interval if the car is not used. It drops uniformly on all corners, therefore I don't thinks it's a valve issue. The compressor seems to be working fine and there are no faults in the dash or error codes when using the iCarsoft diagnose tool.
Would it be correct to assume the problem is the air reservoir not holding pressure? If so, how do I diagnose it?
Thank you all in advance.
Post #656963 17th Feb 2023 4:58pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
i have same problem have cheched all air bags and can see no bubbles when sprayed with soapy water.......?
Post #657079 18th Feb 2023 6:27pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi it could be the air tank or could be one of the valve blocks behind the wheel arch covers 1 driver-side rear arch and 1 valve block drivers side front arch new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #657081 18th Feb 2023 7:03pm
Cosmin
Thank you, Oggy.
How does this system work, basically? The compressor pumps air into the reservoir, which then sends air to both valves, each with its two bags. What holds the pressure in the bags? I'm assuming the valves do.
If that's correct then the reservoir is not the issue.
Would you agree?
Post #657086 18th Feb 2023 8:38pm
oggy
yes cosmin i would agree with that new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657090 18th Feb 2023 8:45pm
MR GLOVER
my air tank had a small rust hole in so changed tank but it still does it ................think all 4 of my air struts are original
Post #657134 19th Feb 2023 3:37pm
Cosmin
Thank you gents.
I'll order the valve oring kit and compressor repair kit to see if that solves the issue.
Will update asap.
Post #657722 25th Feb 2023 11:09am
