![]() | Home > Maintenance & Mods (L322) > Differential Pressure Sensor - No Reading 0n IID |
WRT the differential pressure sensor, take it off the pipes and check for moisture / chemical contamination. Also blow down the pipes, doesn't need to be high pressure, just to check for a blockage or restriction. With the sensor pipes disconnected - or even with them connected and the engine stationary, you should get 0kPa, or very close to it.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Many thanks for your reply Phoenix.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Hi John, I fitted a new expansion tank and although I didn't have an overheating issue I struggled to get a consistent level in the tank.
Hi Kev,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
The 4.4 petrol engine is a BMW unit, the 4.4 diesel is a Ford engine... can't see the thermostats being the same...!!
Hi Pete,
Cheapest things first and IMHO that could be an air lock... maybe try bleeding it a few more times... Pete
Hi Pete,
DPF differential pressure is not available directly on the GAP IID tool so you have to look at the voltage and then reference the workshop manual to see the operating range under different loads and RPM's
Thanks for the advice JayGee,
upagreen1 Member Since: 21 Feb 2021 Location: Yorkshire Posts: 9 ![]() ![]() ![]() |
now then. did the "two o rings on the throttle body connection" prove to be a permanent fix ? I have a similar issue where the throttle body was moveable back and forth by a couple of mm, though there is not much oil residue to speak of. I have also had dpf issues (it went to red with no amber warning and soot levels increase in just a few miles especially with high revs).
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 123 ![]() ![]() ![]() |
Hello All,
25v is likley0.25v and maybe the OP calculated the pressure ?
