Home > Technical (L322) > Auxiliary Power Socket question.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
All my auxiliary power sockets only become live when the ignition is turned on, but the user manual seems to think otherwise…
”Auxiliary power sockets remain live with the starter switch turned off. Battery drain resulting in failure to start the engine may occur if accessories remain plugged in whilst the engine is switched off.”
Did they change this in later cars or is mine an anomaly?! 2009 pre-facelift 3.6 TDV8.
Post #656908 17th Feb 2023 1:26am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
My 2008/9 Vogue had a constant live in the boot cigar-plug socket. My 2012 has nothing left live a minute after switching off the ignition. All the cigar-plug sockets stay live for a minute after engine off, but then go dead! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #656910 17th Feb 2023 7:41am
KitTheRam
I need to double check the boot one but all three 12v sockets in the car lose their live the moment the ignition is turned off. Strange that it is both different from yours and the user manual.
Guessing there is no hidden way to control this that I don’t know about but the previous owner did?! 2009 pre-facelift 3.6 TDV8.
Post #656916 17th Feb 2023 10:32am
mjdronfield
The later ones don’t stay live. My TD6 did. I spent best part of £300 on a decent coolbox that now won’t stay on without the engine running.
There is a relatively simple mod you can do in the rear fuse box to make them permanently live, not done it myself. Think there is a how to or similar on the forum somewhere.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #656922 17th Feb 2023 11:10am
Discotigger
All the accessory / cigar lighter sockets are controlled via relays, which shut down the circuit to those sockets on engine off. I had some of my sockets live after ignition off and after doing some hunting found out the reason. Some vehicles have the relays removed and a metal bypass link inserted to keep them live permanently. If you check the wiring and relay configurations for the Range Rover electrical systems it will show which relays control what sockets. You can remove the relevant relay and install the bypass link to make the sockets permanently live. Thumbs Up
Post #656939 17th Feb 2023 2:31pm
KitTheRam
That’s interesting and hopefully simple to change if needed.
In truth I’m fine with mine being off when the car is off, it’s either a usb phone charger or an electric tyre inflator that I need it for so light use at best. Will check the boot one but from memory that is off all the time too. 2009 pre-facelift 3.6 TDV8.
Post #656962 17th Feb 2023 5:34pm
TDV8 Paul
My 07 boot one stays live and that’s where the electric cool box lives when we use it, the others are switched 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #656981 17th Feb 2023 9:06pm
KitTheRam
Any electric cool box recommendations? Sounds like a good idea… 2009 pre-facelift 3.6 TDV8.
Post #656993 17th Feb 2023 10:13pm
mjdronfield
I bought the Waeco Tropicool TCX 21. It's German, so must be the best.... it also heats up as well as cools, so ideal for the takeaway trips.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #656998 17th Feb 2023 10:42pm
KitTheRam
Thanks. Will check them out. Ideally want something a bit more compact! 2009 pre-facelift 3.6 TDV8.
Post #656999 17th Feb 2023 10:52pm
mjdronfield
They make smaller ones, but the build quality is nice.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #657003 17th Feb 2023 11:19pm
KitTheRam
Thanks. I imagine I would utilise one mostly on the move but going back to the threads main question - if my boot 12v does work with the engine off how long would I be able to use say a small 8L cool box before it would drain the battery? 2009 pre-facelift 3.6 TDV8.
Post #657006 17th Feb 2023 11:30pm
mjdronfield
Not answered your question I know, but you can get a power lead add on that cuts the power if the battery voltage drops too much.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #657007 17th Feb 2023 11:49pm
KitTheRam
Good to know. I take it the L322 never came with an centre console fridge option like the L405’s? 2009 pre-facelift 3.6 TDV8.
Post #657011 18th Feb 2023 12:02am
Phoenix
Assuming it is a Peltier type, take the current rating and divide the Ah rating of the battery by it. That will give you the number of hours before you need a jump start. e.g. 110Ah battery will supply 7A for ~15.7 hours, but you need to take off the starting current (glow plugs & starter current for ~20 seconds) so that you leave enough headroom to start the car. Or get yourself a voltage dependent relay that will shutoff at 11.6V, that should leave you just enough to start the car, assuming it's not winter temperatures - because you wouldn't need a coolbox if it was.
Post #657014 18th Feb 2023 12:09am
