Home > General > 4.4TDV8 Buyers guide
Slow progress
Good evening all,
Is there a specific buyers guide for the L322 4.4TDV8? What things are there to look for vs. the TD6?
I seem to recall a turbo drain modification being required, how do you check it’s done?
Many thanks,
David L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #656245 10th Feb 2023 9:20pm
mjdronfield
It’s only required if it smokes. Some never need it. Mines fine.
Main issue is the oil cooler leaking oil down the back of the engine…. And mixing with coolant if left… so check no oil in coolant.
I’m sure there was another post somewhere with further comments.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #656249 10th Feb 2023 10:40pm
mjdronfield
https://www.fullfatrr.com/forum/topic44115.html?highlight=fault
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #656250 10th Feb 2023 10:46pm
Slow progress
Thankyou 👍 L322 TD6 2003
Post #656290 11th Feb 2023 5:12pm
JayGee
As you already own and are familiar with the L322 there are only a few additional common issues with the later 4.4TDV8;
Oil leak from the oil cooler - easy to spot looking under the car and for oil in the coolant header
AC compressor failure - harder to spot in cold weather.
Front belts tensioner and pulleys - noise on cold start and belt running off the tensioner centreline
For teh rest just plug in your GAP IID tool and run a scan after a run to see what comes up. 2012 TDV8 Vogue (L322)
Post #656331 12th Feb 2023 11:29am
Slow progress
Sorry to open this up again!
SWMBO has been looking at various vehicles, but has asked the question is a 105,000 mile 4.4 tdv8 L405 better than a 70,000 mile L322 4.4TDV8? As they are similar prices !
I’m not sure in my own mind, so thought I’d ask the experts!👍 L322 TD6 2003
Post #656827 16th Feb 2023 7:46am
mjdronfield
I think no matter what replies you get to that question, you will have to drive both and make your own mind up…. Taking replies into account obviously, but there are folk that go to a 405 and love it, folk not sure, folk that wish they had kept the L322 and folk that sell their L405 and get another L322…
The 405 is all aluminium, lighter, faster, more fuel efficient…. Sounds like Steve Austin 🤣, but some say it feels less of an occasion and more like a car…..
The boots smaller, and the front door opening is a bit tighter so if you are tall, you will have to duck more….
But then you can get an opening panoramic roof and the signature hi fi…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #656832 16th Feb 2023 9:03am
Slow progress
Are the engine and transmission the same? L322 TD6 2003
Post #656836 16th Feb 2023 11:17am
mjdronfield
Pretty much I believe. Transmission the same though I think the SDV8 405 had a bit more power.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #656837 16th Feb 2023 11:35am
JayGee
Later SDV8's have extra emissions parts to make them Euro 6 standard / ULEZ compliant. 2012 TDV8 Vogue (L322)
Post #657216 20th Feb 2023 1:49pm
4wheeldriver
Hi all.
I'm away to look at a 61 plate 4.4 td V8 Vigue tomorrow but looking back through the MOTs for past couple of years its needed/needing lots of suspension repairs as in below
November last year MOT
Offside Front Lower Suspension arm ball joint has slight play (5.3.4 (a) (i))
November 2021
Offside Front Anti-roll bar linkage ball joint has slight play (5.3.4 (a) (i))
Offside Rear Anti-roll bar linkage ball joint has slight play (5.3.4 (a) (i))
Are these common faults or could there be something more suspicious behind it?
Thanks for any advice.
Post #657686 24th Feb 2023 8:31pm
mjdronfield
I’d say that’s pretty common on a car that’s best part of 3 tons. Just had all mine done. Parts aren’t daft expensive but can be a pain to do if you need to get old ball joints out.
ARB drop links are just 2 bolts.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #657689 24th Feb 2023 9:19pm
mjdronfield
I’d always do both sides if it were me. Just reread your message and I might be wrong saying ARB drop links, don’t think that’s on there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #657690 24th Feb 2023 9:21pm
4wheeldriver
That was copied and pasted from the MOT cgeck page. Prior to the last two years its been ok on MOTs. Failed once on tyres down to convas which did raise an eyebrow as to could the guy not afford to look afyer it properly. That maybe my suspicious mind tho. 🤣🤣
Post #657691 24th Feb 2023 9:26pm
JayGee
It’s normal that a reason for sale is the owner can no longer afford or justify the running costs. This is why L322 ownership is now the preserve of enthusiasts with either more money than sense or no sense at all.
The purchase price of an L322 is the cheapest part aspect of ownership… 2012 TDV8 Vogue (L322)
Post #657695 25th Feb 2023 4:07am
