Home > Maintenance & Mods (L405) > Rear Brake Rotors
tangerine912
United States 2016 Range Rover HSE TDV6 Fuji White
Rear Brake Rotors
Looking to install new rear rotors on a L405 TDv6 HSE.
Considering these options:
https://www.brembostoreusa.com/product/disc-brake-rotor/09B50411 Interchange: LR033303
https://www.brembostoreusa.com/product/disc-brake-rotor/09B50311 Interchange: LR033302
Only difference I can tell is that the first option is diameter 365 vs 350mm. Both LR033303 and LR033302 show fitting my model and year.
Does anyone know the differences and will either fit?
Post #656745 15th Feb 2023 2:40pm
Gremlin500
Hi,
I think only the smaller disc will fit a standard TDV6 which has 365mm front and 350mm rear discs.
The 365 will foul the rear caliper.
It’s possible to upgrade the brakes to the larger ones all round, but not cheap, there are a few threads on here if you search.
Only the V8’s had the option of the big brakes, including the front 6-pot Brembo’s. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656746 15th Feb 2023 2:49pm
Gremlin500
These pics explain:
i.e. hard to see on the bracket pic, but the caliper mounting holes are at a radius 7.5mm larger with the red bracket than the original bracket.
In short, bigger disc needs bigger bracket! Very Happy “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656751 15th Feb 2023 3:03pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
My SCV8 has 380/365 rotors.
Yours should be 365/350.
You can upgrade to the larger brakes if you have time and money. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #656752 15th Feb 2023 3:20pm
