Home > Technical (L405) > immobiliser vs cabin preheat |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1236 |
I can confirm with the Ghost 2, that I now cant use the cabin pre-heat with engine start etc from the IC app.
15th Feb 2023 8:55am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 779 |
Your profile says you have an AB, so you would use the remote to pre-heat the car (or set a time in the infotainment) which doesn’t start the engine, so I can’t see it being an issue with an immobiliser. MY23 Panamera E-Hybrid
15th Feb 2023 8:58am |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 490 |
Hi Kot, I shall look into the Ghost (using the Ghost2 app)
15th Feb 2023 9:32am |
You can get a remote for the pre-heater, I would.
15th Feb 2023 10:53am |
fantastic, that gives me some options.
15th Feb 2023 7:53pm |
6885leem Member Since: 23 Jan 2023 Location: North East Posts: 9 |
There's a great video on YT re Ghost2 - check out SASMobile. They've done a SVR where it locks out the gearbox rather than the engine so the remote start still works. |
16th Feb 2023 6:18pm |
Originally there were issues using the transmission lock but think this may have been resolved.
16th Feb 2023 10:38pm |
I forgot about the timed climate function on the internal screens, that may be my solution especially if I can get it to operate off a remote. How can I tell if mine is compatible with a remote? Buy one and try it o can I find out of a spec sheet/look of built in kit? First time FFRR owner |
18th Feb 2023 9:01pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Ask your dealer to check? I did and they ordered in two & programmed them for less than £50... |
19th Feb 2023 12:27am |
fabulous, thank you sir, I shall try that avenue First time FFRR owner |
19th Feb 2023 12:34am |
