Home > Maintenance & Mods (L322) > Not so good news - possible new gearbox |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Before spending that sort of money it would be worth checking the transmission has enough fluid and perhaps changing the fluid, those symptoms could be sympotamic of low or bad fluid. |
13th Feb 2023 3:59pm |
Iguana Member Since: 30 Aug 2015 Location: Somerset Posts: 28 |
Thanks Kesbo, sorry I should have added that we checked all fluids at the weekend and all are clearly recent and at the correct levels Iggy/Ieuan
13th Feb 2023 4:23pm |
Any receipts suggesting whether the right fluid was used? It could be some generic trans fluid was used and the gearbox doesn't like that. However, like your original post indicates there maybe is a problem and the fluid was changed but didn't solve the problem. Good luck! |
13th Feb 2023 4:41pm |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
As it's still working I'd be inclined to invest in a gearbox flush (look up "Bodsy".)
13th Feb 2023 6:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
Fatty off roader was bought with a known gearbox fault, same issue as yours, I managed to coax about 9 months out of it before having to replace the gearbox... I changed the oil and it made it slightly better but it didn't last...
14th Feb 2023 9:35am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 749 |
Personally I would pause before you commit to spending anything and give the whole car a very good inspection.
14th Feb 2023 11:58am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 |
If you have the facilities & you’re handy with a set of spanners you should consider remanufacturing your transmission yourself. The hardest part is getting it out of, and back into, the vehicle. Tearing down, repairing & rebuilding the ZF 5HP24 transmission really isn’t that difficult. This would massively cut down the cost.
14th Feb 2023 2:32pm |
