Home > Maintenance & Mods (L322) > Hive mind question on a leak
Jimmies
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Bournville
Hive mind question....yesterday I replaced the oil cooler seals due to an oil leak at the bottom middle of the engine...... took her for a spin after and two things happened
Firstly I got a restricted performance message....but I think that might just be that I forgot to fully tighten the plenum to manifold seals.
Secondly there was still fluid ( I think oil but not 100 percent sure it was only oil) leaking when the engine is running. See last pic for leaking
Today I took her apart again to look at the cooler and it doesn't look like new oil is coming out from the cooler( pics attached)
Any ideas of what else I could be looking for?
Post #656532 13th Feb 2023 9:27pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Was it all cleaned up before reassembly? Did you replace the two o-rings on the oil feed pipe to the cooler at the same time? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #656539 13th Feb 2023 11:03pm
Jimmies
I did replace the o rings on the pipe at the back.. that was the first thing I did
Post #656541 13th Feb 2023 11:39pm
JayGee
The cooler can warp and crack so even after replacing the seals it can still leak. If it’s not oil leaking then the only other fluid is coolant but it should be easy to tell by look and feel. 2012 TDV8 Vogue (L322)
Post #656548 14th Feb 2023 6:52am
JMC
What torque settings did you use for tightening it all back up? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #656554 14th Feb 2023 9:14am
Jimmies
I ended up putting in a new cooler and I.....think.....the leaks have stopped
Post #657066 18th Feb 2023 2:08pm
