Home > Technical (L405) > Completely dead (well almost)
dickster1234
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
I have 2019 L405 3ltr diesel autobiography…I’ve had it since new and other than a few minor issues its been a thoroughly reliable. However recently when I’ve been washing it Ive tried to open the boot to wipe the sills and whilst boot unlocks it doesn’t actually open i.e. the normal process of the hatch auto opening doesn’t happen and I have to heave it up manually. This however isn’t the main issue as when I return to start the car its completely dead; well not completely dead as it locks and unlocks with the remote and interior lights are working but the car won’t start and all the in car displays are completely blank.
The only way to fix it (that I’ve found) is to disconnect and reconnect the battery following which everything jumps back to life!!
Anyway just wondered if anyone else has had this issue and if there is another way to reset everything without disconnecting the battery because as anyone who has carried out this task knows’ it’s a right pain in the backside!!
Post #656466 13th Feb 2023 2:23pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
And it starts absolutely fine once 'reset'? I was going to say it's probably just the original battery on its way out but that does sound strange.... Could well just end up the battery is on its way out though... FFRR SDV8 Autobiography
Post #656469 13th Feb 2023 2:49pm
Dolphinboy
second battery died and draining the main one? It happened to me on my old 2004 which had a second battery fitted.
Was driving along and the whole car died, engine, lights, everything. turned out the 2nd battery was draining the main one until there was no power left.
Post #656471 13th Feb 2023 3:04pm
Boot opening is the first thing to fail with a worn out battery so I'm with the others... check the voltage on both of yours... Thumbs Up Pete
Post #656475 13th Feb 2023 3:27pm
dickster1234
Thanks everyone and good advice...I'll check the battery!!
Post #656477 13th Feb 2023 3:45pm
