Home > Technical (L322) > 2011 TDV8 front cv gaiter keeps coming off
Seancod
Wonder if anybody had the same problem or are able to point me in the right direction. I changed both front outer cv gaiters a couple of weeks ago and shortly afterwards noticed that they had come off the cv joint. They where oem gaiters and clips, i have the special pliers to crimp the clips. I salvaged the clips and tried again. They came off again when i raised the suspension and went lock to lock. I changed the clips and they still came off and then used heavy duty zip ties. This worked but after a few days one of these has come off. When I tighten the clip i jack the suspension so it is at normal ride height, this also makes the angle for the gaiter level to go over the cv joint. When the suspension is all the way down, the angle is to difficult to hold the gaiter on and tighten the clip. What is the right way to do this. Any insight would be very gratefully received.
Post #656361 12th Feb 2023 5:13pm
Phoenix
Take the driveshaft out, do it on the bench. Clean the boot and the clamping surfaces - also make sure the inner is in the notch, not beyond it. I've never had an OEM or good quality aftermarket boot come off if positioned & clamped correctly. Don't bother trying to re-use the clamping rings, once they've been fitted, they're not able to be refitted with the same holding force.
Post #656364 12th Feb 2023 5:22pm
Seancod
First time round, I had the driveshafts on the bench and was quite sure I had them on on good. I can’t get clips on their own so will have to go for another gaiter kit and strip down again.
Post #656369 12th Feb 2023 5:35pm
Phoenix
Make sure there is absolutely no grease under the boot where the clamping rings go, that will cause it to work loose fairly quickly. Have a look for GKN kits, a bit cheaper than LR, they're the OEM so will be the same quality.
Post #656377 12th Feb 2023 6:42pm
Seancod
It was the GKN kit i used, i was a bit liberal with the grease though. i will do again and take better care. Thanks for the advise.
Post #656388 12th Feb 2023 7:22pm
Phoenix
You also need pliers capable of applying some force, these are similar to mine, they have a compound action. If yours are the single action short handled ones, you might need to use a big pair of grips to pull them fully closed.
Post #656389 12th Feb 2023 7:34pm
Seancod
Yes, they do look better than my ones and I did have to put a lot of pressure on them, Allright for normal motors i suppose.
Post #656394 12th Feb 2023 7:49pm
dingg1
I had an absolute nightmare with mine, big end outer on front shaft, kept popping off after the monkey replaced it after burning through it with a blow torch, in the end, after going through lots of the proper clamps, getting covered in that black grease each time, I resorted to using a big jubilee clip, been on now for about 8 months and no issue, not ideal but it works...
Post #656395 12th Feb 2023 7:51pm
Seancod
Yes, i can see that working, might do that for now and put on the todo list to sort later. I suspect that the cv's will need changing now as i did drive them a while before i had found out the boot had come off.
Post #656396 12th Feb 2023 7:57pm
Phoenix
CV joints are pretty resilient, if it's not clicking on full lock and/or offroad height, it'll likely be fine for many thousands of miles yet. If you have the direct action pliers, then just use a big pair of grips to pull them closed. Jubilee clips are generally wider than the groove in the CV boot, and unless the stainless steel variants, won't put enough clamping force on the boot to make a permanent repair. Cleanliness of the mating surfaces is key to a 'right first time' repair though.
Post #656397 12th Feb 2023 8:05pm
