Home > In Car Electronics (L405) > Sat Nav Map upgrade
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Sat Nav Map upgrade
Well I have succumbed to the temptation and bought a map up date (NOT OFF EBAY) from a UK company selling sat nav updates via download or by usb stick. They guided me through downloading, opening via Zip and putting on to a 32gb USB stick. On receipt of my Vin number, have supplied me a code to make it operational.
Only problem is...it takes 3 hours of your engine running to download it on to the vehicle. You can't just pop a charger on to the battery and do it because the ignition times out and shuts down.
This is why I don't believe that man walked on the moon !
Would you leave an engine running for 3 hours , obviously somewhere secure.?
Post #656333 12th Feb 2023 11:52am
l405?
you can leave the usb plugged in and use the FF normally...apparently the nav will continue its update everytime you re-start you engine.. ... - .- -.
Post #656341 12th Feb 2023 1:26pm
Phoenix
Charger on, drivers door & bonnet not latched, ignition will stay on. In any case, it will resume when the ignition is back on, as noted above.
Just make sure all other consumers (lights, HVAC etc.) are off to give your charger a chance of keeping the voltage above the power save threshold.
Post #656343 12th Feb 2023 1:49pm
Gremlin500
@DaveK:
Useful if you can add your vehicle to your profile to get better model-related advice?
Phoenix is right, but where did you hear 3 hours? Assuming L405, my MY2017 usually takes 15-30 minutes on a drive depending on the size of the update. The only time I had a lot of issues with uploads was with a weak battery, causing updates to take a long time then fail. I suggest you check the system voltage if this is the case. (A healthy battery not connected to the vehicle should ideally put out around 12.6V). As soon as I replaced my battery, all of the problems vanished. Since then, I have been able to upload on the drive with CTEK charger attached, engine off ignition on, simply pushing the start button again if the shutdown sequence commences. (Thank you Pheonix, next time I’ll unlatch the bonnet too! Bow down Embarassed ).
Best of luck getting it sorted Dave, report back and we’ll try to help further Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656347 12th Feb 2023 2:18pm
DaveK
It is in my profile. Click on the car image on the left. Been there for years ?
Post #656404 12th Feb 2023 9:34pm
Gremlin500
Hi Dave, so very weird there was no car icon whatsoever there on your profile earlier today, but I see we have the same vehicle!
Get one of these: £18.17 40% Off | KINGBOLEN BM580 Car Battery Tester 12V 6V CCA Circut Tester Cranking Test Charging Tool BM550 Automotive Battery Analyzer Kw208
https://a.aliexpress.com/_EwDaGP3
Having been through similar issues, I will be glad to try to help you. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656411 12th Feb 2023 10:55pm
Gremlin500
Hi again Dave,
Read this thread, it may be useful:
https://www.fullfatrr.com/forum/topic63745.html
Post back if no luck. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656412 12th Feb 2023 11:03pm
DaveK
Big Cry Engine running, stick recognised, code asked for…. Then nothing for 40 mins. Said data was loading but never moved off 0%. Then message saying maps failed to load, please reinsert disc ( ie usb stick). So what now. Have emailed company that supplied download ( they don’t have a phone number ! ). Of course original sat nav now kaput
Post #656467 13th Feb 2023 1:28pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I have recently updated my sat maps. I ordered a USB stick from the supplier as I read about people having issues with the download. I know the USB has to formatted a certain way for it to work. I would contact the supplier and ask for a USB stick.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #656473 13th Feb 2023 2:18pm
Gremlin500
Hi Dave,
If the car recognised the stick, it’s not a formatting issue.
Your description of the problem is almost identical to what I had, which was two issues at the same time, therefore very difficult to diagnose, namely weak battery and corrupted download.
The faster the internet connection the better, if it takes hours there is a higher chance of file corruption.
So, check your resting battery voltage (disconnected from the vehicle).
Do the download again, and allow the Here downloader software to reformat the stick if it wants.
Rinse & repeat. Good luck!
FWIW, I had repeated failures with one issue of the maps, despite multiple downloads and upload attempts.
Then I changed the battery and a new map issue became available, this downloaded in half the time, and uploaded to the vehicle in 15-20 minutes, using the exact same 64Gb USB stick. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656481 13th Feb 2023 2:57pm
DaveK
Brand new batt on vehicle, Ran the engine and had batt charger hooked up.Ive asked them to send me a usb stick with it already on. If that fails to work then it's refund time but of course, I'll be left with out LR's built in Sat nav because that is now corrupted by my attempts to load the new maps.
Post #656510 13th Feb 2023 5:32pm
Gremlin500
Ah, sorry Dave, I forgot you got a 3rd party map, my experience was with the JLR download & software. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656519 13th Feb 2023 6:43pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi where do you buy this update from please. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #656848 16th Feb 2023 1:36pm
IGP
I got mine from here
HTH
Post #656852 16th Feb 2023 2:13pm
officially from here,
https://here.navigation.com/brands/Catalog...REEMEA/GBP ... - .- -.
Post #656853 16th Feb 2023 2:14pm
