Home > Maintenance & Mods (L405) > Rear pads advice |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 288 |
Are the new pads gold plated? 2013 Vogue SE SDV8
17th Nov 2020 3:55pm |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
Typical Ratstones!! 2010 defender utility
17th Nov 2020 4:01pm |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 482 |
always surprises me that the rear pads wear the most on the Rangie. Normally its the front pads! 2017 Range Rover Vogue V6 Diesel
17th Nov 2020 6:39pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8538 |
There is a button combination to put the park brake in service mode, which parks the EPb off the disks and resets the pads to the right position after once released.
17th Nov 2020 8:09pm |
This is a Range Rover Sport but the process is the same. Tells you how to set the park brake.
18th Nov 2020 1:22pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Wow - Stratstones Cardiff fixed price website shows rear pads as £194 and rear pads and discs for £449
18th Nov 2020 2:30pm |
Fitted new EBC Greenstuff rear brake pads to the L405 TDv6 yesterday. TRW callipers (existing Greenstuff pads had been on about 3 plus years and were not done but were ready to be changed IMO. Genuine LR rear discs were replaced 3 years ago, no lipping at all and VGC on inspection so didn’t replace the discs). Have found the EBC greenstuff pads to be very very good pads all round with minimal dust, never any squeal, durable and great performance. Swear by them. Paid £53 for the rear pair of pads this time. The EPB maintenance mode sequence referenced here is very helpful. No diagnostic tool needed. There are YouTube videos on how to do it anyway, both to put it in service mode and to later release service mode. Found it challenging (and very sore on the hands) to get my caliper rewind tool to wind the piston back on both rear callipers (perhaps my poor technique but didn’t enjoy the rear piston wind back at all). The rears do need to be wound back, not pushed in. Easy job other than that but by god I did find winding back those rear pistons a pain, literally… |
11th Feb 2023 7:42am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1139 |
11th Feb 2023 9:57am |
Yes, watched that too and it’s very good although his brake piston rewind tools were different to the ones that frustrated and gave me sore hands…. and they always make it look slick in the corporate ‘buy from me’ 😂👍 |
11th Feb 2023 9:07pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
I have this kit. Works perfectly for my backyard mechanic needs.
12th Feb 2023 4:55pm |
That’s the same set as I’ve got… found it very sore on the palms of the hands trying to wind the pistons back and they took ages… must have been doing something wrong… |
12th Feb 2023 5:23pm |
If you are trying to turn it by hand, then yes it is hard. Hold the small t-handle in one hand and turn the big nut with a wrench. The wrench does the work, not your hand. Everything should be a little loose in the calliper too. This method gets the pistons back in a minute or two. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
12th Feb 2023 5:25pm |
What is the recommended RBP ? Is it best just to get from the Duckworths? I see pld uses EBC anyone uses others? overfinch modified |
12th Feb 2023 6:45pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If you have an air source, these are much better - same as the snap-on ones sold for ~£200 (I never buy snap-on) Mine is a Laser tools branded one, all made in the same Chinese factory.
12th Feb 2023 6:51pm |
