![]() | Home > Maintenance & Mods (L322) > Locking Rear Diff Fault P186D P080A P0806 Now Fixed |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2634 ![]() ![]() |
Has any liquid found its way onto the TR switches, either a spilt drink or rain? The cause of the comms faults is likely to be the reason why the switch isn't working properly.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 900 ![]() ![]() ![]() |
Thanks Graeme - no spills since I’ve had it and no obvious evidence of it happening previously, but it may be worth me pulling the switch out & checking the connector contacts |
You would have to apply to GAP to purchase the updated software.
Thanks again Graeme - looks like it’s £30 per ECU update file so I’ll look into that, although per the iid tool, I have a few modules that are not on the latest update, not sure if there’s value in updating them all for the sake of it.
The TR module is in the centre console - the various TR switches are attached to it.
Having researched the issue further, I believe the problem is directly related to the fault with the locking rear diff actuator, I’ve found an LTB that describes the issue exactly (LTB00228NAS4) and the solution is to fit a new locking diff motor and download the latest diff ECU update, which I’ll obtain from GAP using their Fastlane service, then run the diff self-test procedure on the GAP tool.
Locking rear diff. motor replaced today and pleased to report all faults are now cleared.
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
Many thanks to the above poster for their pointers,just spent the afternoon doing the exact same pig of a job
