Home > Technical (L322) > Suspension leak, one corner dropping. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
It is worth reseating the pipe at both ends as if it doesn't get caught properly it will still work but will be loose I had this on my old p38 |
16th Aug 2017 1:15pm |
and check whether the end has been trimmed when they put new bag on if at an angle it can allow a seepage under pressure |
16th Aug 2017 1:16pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I had a bit of time over the weekend to have another look at this and unfortunately am no further on.
21st Aug 2017 1:32pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Mine started with "extended, reset height" etc....then progressed to "Suspension Fault" and onto "Special Programmes off" After a full fine tooth comb today, my worst fears are confirmed.....Compressor isn't packing a punch and the seals are shot.
21st Aug 2017 5:55pm |
Thanks Nick, but unfortunately, or fortunately, I'm not sure yet , I'm not getting any error messages or faults and the system is performing as it should except for dropping on one corner....
23rd Aug 2017 10:26am |
I'm still no further on with the dropping corner as I haven't had time to investigate, but this hoot or groaning sound was nothing more than the power steering requiring a top up..... I noticed a slight sound sometimes after start up and occasionally under breaking or turning to the right, which was engine speed related, heard it one morning after start up, turned the steering wheel and it was slightly louder, level was just off the dipstick, quick top up and the noise has disappeared, haven't had a chance to have a good look for leaks but nothing very obvious. I need to take a few days off to show my FF some love, been busy lately sorting out a Mitsubishi L200 limp mode problem for a friend which was driving me crazy but finally sorted. |
6th Sep 2017 10:47am |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 |
I have been reading your column. Did you manage to find the fault and n the end as i now have the same problem 😱😠|
18th Sep 2018 12:48pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3775 |
It may not be relevant but I had one of the rears dropping and of course feared the worst but it turned out to be a faulty height sensor - replaced it and had no problems since Geoff |
18th Sep 2018 4:28pm |
No, I never got it sorted but in fairness, I didn't really look at it too much either. It's over a year now and it hasn't gotten any worse, of course it hasn't gotten any better either....... TBH, I had expected something to have given up completely at this stage but it's all just still the same. I was talking to an indie last week and I just happened to mention it to him and he seemed pretty sure it was the bag, realistically the only way of really knowing is to take it off, stick an airline on it, dunk it in a bath of water and look for bubbles but I just haven't had the time to do it. I know it's eventually going to just let me down (no pun intended) and then I'll have to do something with it. A bit like my sticky starter at the moment which requires a bit of a slap now and again to encourage it to come to life.... Sorry I haven't been more help and hope you get it sorted. |
20th Sep 2018 12:50pm |
Ok thanks |
25th Sep 2018 9:48pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 380 |
sorry i know this is a old thread ..but ive got the same problem rear left corner dropping overnight ,have replaced airbag, stripped cleaned and replaced rubber seals in valve block ,tried soppy water still the same .......but didnt cross my mind that it could be a height sensor as i haven't got an error messages ,but going to replace height sensor and see what happens |
8th Feb 2023 8:55pm |
