Home > General (L460 2022) > L460 Recall for USA
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
L460 Recall for USA
Evening All,
Interesting to see the US has issued this recall on some 6 cylinder petrol engines, interesting if UK vehicles are affected?
OMB Control No.: 2127-0004
Part 573 Safety Recall Report 23V-044
The information contained in this report was submitted pursuant to 49 CFR §573
Manufacturer Name : Submission Date :
Jaguar Land Rover North America, LLC FEB 02, 2023
NHTSA Recall No. : 23V-044
Manufacturer Recall No. : N763
Manufacturer Information :
Manufacturer Name : Jaguar Land Rover North America, LLC Address : 100 Jaguar Land Rover Way
Mahwah NJ 07495
Company phone : 8188500
Population :
Number of potentially involved : 6,644 Estimated percentage with defect : 1 %
Vehicle Information :
Vehicle 1 : 2023-2023 LAND ROVER RANGE ROVER
Vehicle Type : LIGHT VEHICLES
Body Style : SUV
Power Train : GAS
Descriptive Information : Jaguar Land Rover is conducting a voluntary safety recall campaign
involving certain 2023 Model Year Land Rover Range Rover vehicles built at the Solilhull Vehicle
Assembly Plant from August 24, 2022 - November 30, 2022. Approximately 1080 vehicles in the United
States and Federalized Territories. The basis of the recall population was derived the potentially
affected engine serial numbers that were determined based on delivery dates of affected parts into
Jaguar Land Rover's Engine Manufacturing Centre. Affected Engine serial numbers were then traced to
specific VIN's.
Production Dates : AUG 24, 2022 - NOV 30, 2022
VIN Range 1 : Begin : SALKPBFU8PA021265 End : SALKP9F47PA039409
Description of Defect :
Description of the Defect : A concern has been identified on Certain 2023 Model Year 3.0L AJ20-P6 Land
Rover Range Rover, Range Rover Sport, Range Rover Velar, Discovery and
Defender vehicles where in a small number of engines the cam carrier oil
gallery hasn’t been fully drilled. As a result, the oil channel could be blocked,
leading to accumulation of oil against the pressure control valve rubber
membrane, and subsequently an external oil leak or increased oil carryover
into the air intake system.
FMVSS 1 : NR
FMVSS 2 : NR
Description of the Safety Risk : In the event of a blockage, oil can accumulate against the engine pressure
control valve rubber membrane, and subsequently an external oil leak or
increased oil carryover into the air intake system can occur. An external oil
leak may lead to an engine bay fire.
Description of the Cause : NR
Identification of Any Warning
that can Occur :
NR
Involved Components :
Component Name 1 : AJ20 P6 CAM Carrier
Component Description : AJ20 P6 CAM Carrier
Component Part Number : J6P3-6J011-AF
Supplier Identification :
Component Manufacturer
Name : Ryobi Aluminium Casting (UK) LTD
Address : Trooperslane Industrial Estate
5 Meadowbank Road Antrim, Carrickfergus Foreign States BT38 8YF
Country : United Kingdom
Chronology :
Jaguar Land Rover (JLR) received a report from Ryobi Aluminium Casting (UK) LTD, on November 23, 2022
that an oil channel had not been correctly drilled on a small number of engine cam carriers manufactured and
Part 573 Safety Recall Report 23V-044 Page 4
supplied to JLR for installation on JLR’s 6-cylinder petrol engines. On November 25, 2022, Nitra and Solihull
vehicle assembly plants initiated a stop-shipment. Affected engines and vehicles were inspected to identify
potentially affected units. As a result of the stop-shipment, it was identified that vehicles had gone beyond
plant control and an update prior to sale was issued to instruct markets to hold vehicles, inspect the condition
and if ok release for onward distribution. Following this, an investigation was opened at the Product Safety &
Compliance Committee (PSCC). The PSCC requested the Supplier Technical Assistance Team (STA) to fully
define the scope of this issue. At the PSCC on December 07, 2023, the STA team reported their initial findings,
and the Engineering Team was requested to fully assess the impact of the incorrect drilling that had been
reported by the supplier. During December, the Engineering Team carried out physical engine testing with an
incorrectly machined component and reported their findings to the PSCC. At the PSCC of January 24, 2023, the
scope of the issue was finalized, and the consequences of the incorrect drilling was confirmed. Based on the
feedback provided, the PSCC progressed the issue to the Recall Determination Committee (RDC) for review.
The RDC reviewed the issue on January 26, 2023, and concluded that it represented an unreasonable risk to
safety, and a voluntary safety recall should be conducted to inspect vehicles and where an incorrectly
machined cam carrier is found replace with a correctly machined component. There have been no reported
accidents, injuries or vehicle fires as a result of this concern.
Description of Remedy :
Description of Remedy Program : Owners will be notified and instructed to take their vehicle to an approved
Jaguar Land Rover repairer. The technician will inspect the engine cam
carrier and where an incorrectly machined cam carrier is found replace it
with a correctly machined component. There will be no charge to the
owners for this repair. The affected vehicles will be covered under Land
Rover's new vehicle warranty program. Therefore, reimbursements for
pre-notice remedies are not necessary because the affected vehicles are
still under warranty.
How Remedy Component Differs
from Recalled Component :
NR
Identify How/When Recall Condition
was Corrected in Production :
NR
Recall Schedule :
Description of Recall Schedule : Notifications to dealers will occur on February 16, 2023. Distribution of
owner notification letters will occur on or before March 31, 2023.
Planned Dealer Notification Date : FEB 16, 2023 - FEB 16, 2023
Planned Owner Notification Date : MAR 31, 2023 - MAR 31, 2023
Also affected are RRS & Defender, Velar & Discovery
Post #656072 8th Feb 2023 7:50pm
