Home > Technical (L322) > My car has a mind of its own
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
So I lock the car walk away from it and its all ok. Nothing for ages the when sometimes i unlock the car it has a melt down the central locking starts to chirps and it unlock two or three times and the windows come down sunroof opens so far it hasnt rained but the car has been done this over night which is worrying. has it happened to anyone else Thumbs Up
Post #656067 8th Feb 2023 6:46pm
mjdronfield
If you keep the unlock button pressed down, it will open the sunroof and open all the windows, so it could be the fob continuing to send the unlock signal when you are not holding the button.
It’s called global opening. Does it in reverse too…. Keep the lock button pressed and it will shut everything.
Not sure how to disable that feature, which would eliminate the fob if it still did the same afterwards….
Have you another fob you can use for a while to test the theory?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #656070 8th Feb 2023 6:53pm
Simran0211
Yes i have tried repressing the remote when i catch it doing it, I've also changed the batteries I do have two remotes and I've also tried that method but still the same Censored
Post #656071 8th Feb 2023 6:58pm
garyRR
Have you tried using the spare key for a while to see if it does the same? That way you can rule out if it's the car or the key causing the issue.
On the face of it, sounds like it would be worth taking the key apart and checking for button wear, and dirt or water ingress signs. I'd also change the remote battery. 2015 Range Rover Autobiography 4.4 SDV8
Post #656106 9th Feb 2023 12:19pm
