Home > Maintenance & Mods (L322) > Powerflex Poly Bush Replacement
scooby3983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi guys, just curious.
https://www.powerflex.co.uk/products/Range...921/1.html
is it worth doing and anyone got any idea how much a garage may charge to do the complete kit?
Thanks in advance guys
Post #655737 5th Feb 2023 8:53pm
JamboM3
Wouldn’t recommend it unless you want to increase NVH on your luxury vehicle?
Post #655752 5th Feb 2023 10:04pm
scooby3983
many thanks for the reply, greatly appreciated
Post #655753 5th Feb 2023 10:06pm
GraemeS
I fitted these to the front lower arm but didn't like the harshness so reverted to standard bushes. However my std bushes need replacing every year so I'm trialling a set with the rear void filled with marine adhesive/sealant to prevent the front wheels from pulling the arm forwards so readily which tears the bush.
I'd try another set of more flexible poly bushes if they were available.
Post #655768 6th Feb 2023 3:16am
JayGee
My front ARB bushes have disintegrated and apparently the stock bushes are not available as a spare so having to have the whole bar and droplinks done as a set so in this case polybushes would be a sensible and cheaper solution. I've used polybushes on previous cars and when I was younger but now I couldn't accept the compromise between handing improvements and ride comfort. 2012 TDV8 Vogue (L322)
Post #655783 6th Feb 2023 9:17am
GraemeS
The armoured ARB bushes reportedly fit.
Post #655788 6th Feb 2023 9:43am
