Home > In Car Electronics (L322) > 2011 CD changer invalid disc
klf400
Hi guys I know this topic has been discussed before,however the trail goes cold so here we go again.
I have 2 cd changers the one does not play and just says invalid disc ?
The other will play but only the first 1 minute or so of the first track of each disc , will not play track 2-3-4-5-6-and so on
If I give the changer a gentle wack it will go further up to 3 minutes and sometimes the second track will play but only 20 seconds .
I have an ideal of the issue with the second one that plays but would be more confident if someone else comes up with the same idea 🤔
Any suggestions welcomed 🙏 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #655624 4th Feb 2023 10:19pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
watching RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #655647 5th Feb 2023 2:00am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
have you tried a head cleaner like allsop laser lens cleaner new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #655970 7th Feb 2023 9:26pm
klf400
I tried some methylated spirit on a cotton bud , still the same 🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #655974 7th Feb 2023 9:38pm
knares
mine suddenly stopped working
does not play and just says invalid disc RR 2005 4.4 petrol
Post #655995 8th Feb 2023 2:21am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Same problem - happened during the very cold weather if that's significant (condensation?). 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #656065 8th Feb 2023 6:54pm
klf400
We have a result, I decided to look at the cd changer that would only play the first minute or so of the first track of each disc
I removed the cover 4 screws , followed by the cover on the rear that houses the multi plug and circuit board 4 screws + 2 on what looks like a heat dispersal plate ,
you have to peel the warranty label to do so .
Remove the cover exposing the circuit board remove 3 screws to release the top cover.
Once inside remove the 4 shock absorbers and 2 suspension springs then unplug the Ribbon cable from the rear circuit board this will allow the lower cover to be removed just leaving the internal cd changer.
Next turn over the changer so you can see the laser motor drive.
There is a small circuit board held in with 1 screw to be removed adjacent to the motor drive cogs , this will expose a tension spring on the driveshaft for the laser held by 1 screw remove the spring followed by the laser ribbon cable .
There are 2 tabs on the ribbon cables you need to push them back then ribbon will release.
You can now lift the laser head out
On close inspection the drive cog on the worm gear had a hairline crack in it which allowed the teeth to open up causing it to jam .
As I had another changer available I swapped the worm drive from the other and reassembled everything in reverse and it now works perfectly
No luck on the changer that comes up invalid disc 😤
Sorry guys I forgot to take pictures but I do have one of the cog
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #656820 15th Feb 2023 11:59pm
RRfranz
Austria 2011 Range Rover Vogue TDV8 Santorini Black
Hello!
The gear on my CD changer also broke.
Replacement from a second device and works perfectly.
The gears are also available to buy individually.
[img]https://www.fullfatrr.com/gallery/albums/userpics/27082/normal_20241101_170220.jpg[/img]
Post #703749 4th Nov 2024 6:56pm
klf400
Do you have a link for the gear to buy? 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #703759 4th Nov 2024 8:24pm
RRfranz
Hello!
Search for clarion cd changer gear on aliexpress. Gear has 30 teeth.
I ordered two pieces to try (Euro 13,1Cool
Post #703829 5th Nov 2024 5:51pm
