![]() | Home > Technical (L405) > Converting a TDV6 to a TDV8 L405? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3762 ![]() ![]() |
The V8 Diesel has a different suspension set up, not that is probably strictly necessary but just a thought to add into the equation 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 501 ![]() ![]() ![]() |
most things can be done, it may not be cost effective or mechanically effective though. If it happened to me I'd be tempted to have it broken for parts First time FFRR owner |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
I’m sure someone like Allan Millyard could do something like that but I’m sure it will be beyond most normal people |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7872 ![]() ![]() ![]() |
He’d fit a V10 instead 🤣
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1788 ![]() ![]() |
It is possible, but not practical
Nah - I recon he'd build and fit a V7 just for the hell of it |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1422 ![]() ![]() |
The suspension is only different in terms of the active aspect of it … which works in addition to the actual setup does it not? i.e. the physical arms and struts are the same across both,, but the SDV8’s anti roll bar has an active central component and active dampers, where as the V6 doesn’t. In reality, it’ll just mean a bit more lean on cornering etc … and maybe the damper rate will be different
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Or more likely a Spitfire Merlin/RR engine... ![]() ![]() |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Cam-Tech-Craig, Now you're talking. What a sound that would be. |
