Home > Technical (L322) > Does cold weather - affect air suspension? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Boyles law says the volume of gas is related to temperature but the system will adjust as any change in height will be registered and adjusted for. 2012 TDV8 Vogue (L322) |
30th Jan 2023 12:21pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I've had similar weird goings on with my front suspension airbags over the last few months. Some days, when it's been very cold overnight, i.e. -1 and below, the front end has dropped very low but not quite to the bump stops. As soon as I start the FF the front end rises to normal height and the air compressor kicks in. Driving seems to be fine and no faults, etc., show up either on the dash or GAP IID Tool. Other days the front end will only have dropped a tiny bit, normally when the temp is above 0 degrees. I can leave the FF for a few days and the drop won't increase at all, then start up the FF and she will 'self-level' and all's fine.
30th Jan 2023 4:56pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 398 |
Thanks, @Discotigger
30th Jan 2023 5:05pm |
@ TDV8_Tommy,
30th Jan 2023 5:16pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The air suspension will only adjust downwards whilst the vehicle is not running. It's not uncommon to see the suspension at some intermediate height after a cold night, windchill will make it worse than just a low ambient. Boyles law is the correct explanation. I was in the French alps a few years ago with quite a few L322, L319 & 320's. Daytime was -4 to -10 Deg. C. but overnight it dropped to ~-30deg. C., lower with windchill. All the vehicles had levelled down, the ones side-on to the prevailing wind had lowered more, but all were down to some extent. |
30th Jan 2023 6:22pm |
In the picture, you can see the gap above the front wheel is significantly less than the one at the rear.
3rd Feb 2023 12:04pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
mine does this and has done since i got it 2 years ago!! some days worse than other and normally when temps drop. fire the car up levels it self out and the pump goes off after a min or so.
3rd Feb 2023 1:03pm |
Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 63 |
Hola Tommy, que tal? Yeah, I've been having the same issues with mine here in Norway. Allthough it doesn't drop overnight, leaving it for some time leaves it practically on the pump stops. To add on that my air compressor is on it's last legs, and refuses to present itself for work if temperatures are below -4 degrees. Not a good combination. And to top it off my front height sensors decide to go into strike at said temperatures, claiming to have the front suspension on the bump stops while cruising on the highway. I usually bring my GAP-tool and keep deleting the faults constantly for 10-15 minutes, then the issue seems to go away. I'll be upgrading to an AMK within the month, and see if that solves the problem, as well as go over the height sensors with contact spray, or even changing the alltogether. For your issue; I seem to remeber there's a fuse you can pull to diagonse where the kneeling/dropped suspension comes from? |
3rd Feb 2023 6:58pm |
BTW, you can pull up live values from the suspension with the GAPtool, might give you an idea where the pressure goes?I'm starting to suspect faulty valves, including the exhaust valve.
3rd Feb 2023 8:33pm |
Thanks, @Faukstad
4th Feb 2023 8:21am |
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 |
Here in Norway the car is exposed to very cold temps (-10 to -20) many times over the winter, and only once had problems with the air suspension 2-3 years back. It was totally deflated, but that quickly corrected itself when I started the engine. Probably one valve got stuck/frozen and let the air out over a few days. Other than that I've never had any issues.
4th Feb 2023 8:51am |
Took some live readings and although I am absolutely no expert, it seems to me that there is an issue with the front left corner?
5th Feb 2023 8:16am |
